- Joined
- Sep 17, 2015
- Messages
- 33
I need to deliver 410v (under load) B+ to the plates. I'm using PP 7868 tubes. And 10k output traffos.
The power transformer I have is 250-0-250 CT
Can I get the 410v ?
I SS rectified and got 350v I'm struggling to find a decent way to use this transformer.
I'm kinda failing on a "voltage doubler" with the Center tap attempts.
Can I just ignore the center tap? Ground the center tap? What would happen then?
Should I just get a better suited power Traffo?
The transformer is beefy, it can handle a doubler, I just can't find the correct way to do it with a CT
