CJ
people ask about where to set the bias on their power tubes all the time,
me too!
some of the new tube companies like JJ and Electro-Harmonix seem to prefer different bias points than their early NOS versions,
so if you find a setting you like for a certain tube number and brand, post it here.
this is a site that has info on bias current for different tubes based on plate voltage>
http://www.diyguitarist.com/GuitarAmps/PowerTubeBias.htm
just set a Marshall Super Lead 100 equipped with JJ 6550 tubes to -52 volts, this comes out to about 120 ma for all 4 tubes, 160 ma sounds a bit better but will probably cut down on tube life, so you try and find a balance between tone ad tube life,
here is a site with more info and a bias calculator>
http://www.webervst.com/tubes1/calcbias.htm
me too!
