i've built the P1 amp from ax84.com (SE EL84 with one preamp tube),
and im trying to use the backward trannie thing for the B+.
so i have 6V @ 1A trannie for the filaments of 12AT7+EL84 ,and 2 transformers 9V @ 1.3A for the B+.
i calculated 40mA for biasing the output tube over 250V wich gives
10W of power needed,and the transformers can supply 1.3A x 9V=11.7W
is this correct?
im having problems getting more then 23mA on the cathode of EL84...
i have 250V B+ and 245V on plate,and im using 4k to 4R OT with 4R 10W
resistor as load.
any help would be apriciated....thanks
is this correct?
resistor as load.
