[quote author="PRR"]> If I'm not mistaken, the signal level at high frequencies is *lower* after the first stage + passive filter than on the input!
Probably not a real problem. The output from a dynamic phono needle is VERY hot in the highs. You are really more likely to run into overload than tube noise, even if the first stage and EQ shows a "loss" and the electronic noise level is set in the second stage.
People whine about "low noise" phono stages, but it is mostly bogus. You can use quite rude amplifiers and still recover the surface noise of the vinyl. Not a lot of point in reducing tube noise lower than that. Not a lot of fun listening to a needle or dummy-source when it isn't in a groove.[/quote]
You're not really likely to run into overload on that first stage, or the second stage either. The worst peak output level I was able to measure on a record was the equivalent of ~98cm/sec, on a jumping scratch which was on a 78 by Pope's Arkansas Mountaineers. On a typical magnetic catridge, with 5mV output at 5cm/sec (standard level), that's 98mV. If your input stage gain is 30dB, that's ~3.1V peak output, which a respectable tube circuit should handle without breaking a sweat. If you then insert a passive RIAA or similar EQ network, the same superpeak measures 26dB over nominal level, so if you assume that the preamp should boost nominal level to -10dBV, the standard consumer level (-7.8dBu), or +18.2dBu, which is about 6.3Vrms, presumably 8.9V peak. No sweat there either for a well-designed tube circuit.
As for noise, as long as you're not trying to amplify a low-output moving-coil cartridge, a tube like the 6SL7, 12AX7, 5751 or the like can do an adequately quiet job. (Cough.) I wrote an article for audioXpress last year outlining noise and overload considerations for phono preamps, and the upshot of it is that a good tube circuit will do fine, way below the noise of any record I've ever owned.
Peace,
Paul
