Kingston
eskimo said:I think I understand most of this circuit, but what does R1, C1 and C7/C6 do?
R1+C1 are the zobel network for the input transformer. Transformers can ring in very high frequencies depending on loading conditions and transformer type. Sometimes audibly, sometimes only visible on oscilloscope and maybe negligible in real world use. Basically, square wave response (transients) might be skewed and you might want to tune that away. Most transformer spec sheets will tell you the optimal zobel, and sometimes only a resistor is needed. If you need to tune it yourself (difficult!) there are some very good threads around here.
And sometimes (most times?) zobel network isn't needed.
C7 and C6 are B+ smoothing caps, sometimes called "stabs", reducing ripple. These values are not critical at all, and anything between say, 10-200uF works. In fact they aren't needed for the amp to work. Depending on how "stiff" (regulated or capacitive) your B+ power is, they might not actually help at all.
[edit]
aww heck lassoharp answered these questions already. oh well the more the merrier.
