I have a tube screamer that is giving me a hard time.
This is the schematic I followed:
http://www.tonepad.com/getFile.asp?id=81
Strange things is, in test mode it always works,
this is with a signal generator for input and into a fostex active monitor.
When I come home and plug in a guitar and a guitaramp, no sound.
When I roll back the volume on the guitar it suddenly passes sound ???
Q1 is the suspect stage,
in effect mode the bias is correct: C=9V B=3,5V E=3V
when in bypass mode the base drops to 0,2V, emitter to 0V
Only difference in bypass mode is that the input goes to ground, and a signaling led is disconnected from ground.
I highly suspect the 0,027uF input capacitor,
but cannot explain for myself why the circuit behaves like it does ??
Can someone enlighten me a bit?
