denimdragon
New member
- Joined
- Nov 21, 2019
- Messages
- 4
This is most likely an operator error, but the booklet say that a good 6L6 should read 43. I tried two NOS 6L6s and the meter went right to 120. Now take this
all with a grain of salt because I am new to tubes, and tube testing. However, I read/take instructions pretty well so I believe I am doing everything correct. I guess
my question here is, is that normal for it to read that high?
I have diassemblied the unit because whenever I get old gear, I inspect it to make sure that there isn't any obvious visible issues. I have already replaced the bathtube
capacitor the was attached to the meter terminals and replaced it with a new 100uF 35Volt Rubycon. The old cap was 75uF and I followed a youtube video on how
to calibrate and restore it (Blueglow Electronics). Mark seems pretty knowledgeable about the testers and was the reason I hunted down the TV-7 unit intially. The
Aplitrex AT-1000 is above my pay grade.
Any guidance on this would be greetly appreciated as I have 1000's of tubes that need testing and I want this to be my main box. I have a Knight 600B, but from what
I have read here, it's good for emmissions testing, so I will use it for that as a way to quick all the tubes before I put them on the TV-7.
Again thanks for any advice on these matters.
