rascalseven
A friend brought by his Ampeg SVT-VR head that he smoked to have burned resistors replaced. Upon checking out the resistors on the power amp pcb I found that many of the resistors (5 ohm 3W and 47.5k 1/2W) are open -- no reading whatsoever. No resistance, no apparent connection from lead to lead. Many, if not most of the resistors on this board are this way.
Even those that have no scorching at all. They all appear to be of the same make, carbon comp. Other resistors of clearly different manufacture all read fine, but the green ones (all look the same, even though two different values) have no measurable resistance that my meter can read. It's as if the meter leads aren't touching anything.
I removed a couple of them completely and measured, and can't get a reading, so it's not adjacent components affecting my meter.
How can several resistors (about 8 of them, IIRC) all go 'open' at once? I'm guessing this had something to do with the thing burning up?
Has anyone had a similar experience? I'd LOVE to understand what happened.
Thanks for any light y'all can shed on this!
JC
JC
