simonsez
A simple question....When should i use a twist cable and shield cable? I thought audio signal is best use shield cable? (wrong?) Thank you...
I can't figure out how to shield wires to/from input transformers. What are you guys using for this?
rotation said:It's called EMI, electro-magnetic interference. I think so.
Twisting wires is against magnetic fields, shielding them is against electric fields. This is what tmuikku told you in his reply to your post, i hope he is correct, i will do some more reading because unshielded wires always bother me. Most of times they are noisy before i move them around a little.
Miha
