And final update: After mailing with Dávid Fehér from this forum he discovered that my mic was simply not drawing power. And I double and triple checked everything...again and again. So, I thought, if the mic is not drawing any power than the tube won't light up. And so was it of course. 8)
Long story short, I took out the tube and looked at the socket. The gold grips that hold the tube pins looked relatively wide to me so I simply took a small screwdriver and bent them all in a bit more dense. Lo and behold.....it worked and I got "normal" measurements.
Then I had to change, as suggested by Dávid, the 56K on the Plate trimmer to about 33K. Then I could calibrate as expected.
Finally I did a sound check: Mic works, in Cardioid mode with low cut and –10db. In Omni it’s very quiet, in Fig 8 I get nothing - no sound - at all. More debugging to do.
One other odd thing I found is although it sounded pretty good in Cardioid mode I found it to sound better with -10db. That's a first for me. Must go hand in hand with the Omni and Fig 8 not working correctly..... :-X
