dirtyhanfri
Hi
A friend of mine has both UA 6176 and 610 MkII channel strips and wants to use the preamp section of them to bring up the stereo mix coming from a passive summing mixer. The problem is the 6176 is around 6db´s lower in the same setting. He brought them to me to compare thinking it was a failure in the 6176, but after tracing the signal I found the loss comes from the output transformer on the 6176. 610MkII uses a Cinemag CM 2810 (9,6K:600r) and 6176 uses an unknown (at least for me) output transformer. You can see it here
Googling EIA606 MS 1335 I found this web http://www.unclespot.com/transformerEIAcodes.html and it looks like it´s a Woodward - Schumacher transformer, but I can´t find anything relevant.
ASSuming the preamp circuitry is the same (more or less, in the construction there are huge differences, like the use of SMD components in the 610MkII) the output transformer should be swappable right? Because I´m thinking in buy a Cinemag CM2810 for the 6176, expecting to have the same level at the preamp output, should it be ok?
EDIT: I keep thinking about it, I recall the output transformer in the 610MkII is soldered to the pcb, but has visible pins, maybe I can get the signal from the preamp output of the 6176 (before the output transformer), put it into the preamp output transformer in the 610MkII and measure the output (with 610MkII unpowered), maybe that way I could try if it works, I´m a bit scared to damage something, nothing to worry about if I just test the transformer with no power in the unit right?
