I have noticed that most preamp channels need the usual 24V or 48V in order to run. Most power supplies I see that work with neve, opamps, or rca show the voltage within that range, however, how does amps or current play into the circuit?
Take this power supply from JLM audio for example. It shows the 24v and 48v lead and on the transformer it says 1.25A for current. In the description its says the power supply can support up to 4 neve style preamps. I guess that is considered the "load" for the PS. Say we hook the PS up to 4 neve style preamp boards and measured the current and not the volts at the leads, would they read 1.25 amps? Or, would the amps be 1.25 amps divided by 4, so 0.3125 milliamps per channel?
What is limiting this power supply to only 4 preamp boards?
Also, if I wanted to buy a power supply for a random preamp I found on the web that operates on 24 volts, how am I to determine the amps or milliamps ?
Sorry for such a novice question.
