meverylame
Member
- Joined
- May 16, 2009
- Messages
- 14
Hey all,
*Cross post from PRW*
I'm managing a facility that has an Amek Angela II. The other day I had a session where I had to use a laptop as a sampler and was playing some songs through it to line check and was pretty appalled by the quality of the channel. Given this is a 20 year old console so its likely pretty due for a recap, the experience did make me wonder about trying to upgrade the VCAs (inline board so and also has a vca on both the big and small faders) while I'm in there. The VCAs in the console is the DBX 2150a that has the symmetry adjustments on the backend, according to the THAT corp guide I need to be using a 2181LB(which is the trimable middle grade modern vca) . Talking to a few different techs I've received a few different responses as to what to do, which is to use the 2181LA (the trimmable high grade modern vca) and also to use the 2180LA (the pre-trimmed high grade VCA). SO, for starters, what do you guys think? 2181LB? 2181LA? 2180LA? Jump off a bridge?
For convenience here's the THAT guide on it:
http://www.thatcorp.com/datashts/dn137.pdf
Secondly, and really my initial question when researching this. I was initially considering using the trimmable style THAT VCAs, and in the guide for replacing them they have a table (see below) with some example values for how to correctly modify the circuit to work given a certain operating voltage.
So they reference having more support for integration on the 2181 datasheet http://www.thatcorp.com/datashts/THAT_2 ... asheet.pdf
For the life of me I can't find any data on this (could be an idiot), but even it ends up being better to use the pre-trimmed VCA, I'd still be very curious to know how to correctly calculate this. Here's the schematic for the board.
Any thoughts? Anyone actually do this mod? Bueller?
Thanks a million guys!
