Here's a PSU filtering electrolytic put in reverse on a steady 15VDC rail
It comes from an Oberheim SEM (Synthesizer Expander Module) in a 4-Voice synth from the late 70s
If you confirm that the capacitor is installed backwards that should be easy enough to fix, but I would replace with a new one if confirmed that it has been used backwards for some time. That can't be good.
Sure, it seems to be backward since the origin, and yes I confirm that I read -15V across it
It doesn't show any leak marks, and it is not swollen, weird..
