Hello,
I have a UREI 529 EQ I've asked a person with competence to modify on my behalf; I'm hoping to have its ICs swapped out at the input and output of its path to (1) be much cleaner, and (2) be fixed-gain at these stages, at higher than net unity gain so this will function as a preamp/eq. Since there are a couple points where it can already be switched (-20dB I think?) or slid (subtractive -15dB) to change its total dB +/- by the time it's at output, I don't feel super concerned about the idea to aim for the +35-40dB range or thereabouts for fixed gain on the ICs.
My hope is that this forum may have recommendations for appropriate preamp ICs that will match well for pin configuration, will be low noise, and will be low-enough power to avoid extra work in that department.
Apologies if I am missing (or unnecessarily including) obvious information; I am moderately ignorant but the tech I'm hiring is not. I would like to minimize extra time he needs to spend researching this by asking, myself.
Attaching 529 documentation. Thank you very much for your time and expertise fielding this question.
