jeffbro
The service manual online does not contain a parts layout and half of the main PCB is obscured by the metering daughter board so the reference designators are not visible. Can anyone point me to a parts layout?
The unit I'm working on has one channel that goes into max gain reduction when the RATIO knob is turned fully CCW to turn on the AUTO function. MANUAL mode works fine, and I don't believe the AUTO switch is at fault. I'm trying to trace signals on the foil side of the board but don't know which IC is which.
