thedug Well-known member Joined Jun 13, 2004 Messages 235 Jan 30, 2005 #1 Can you use an insert as a direct out.. i.e. Can you just tie pins 2&3 together on the board side and tie that to pin 2 on the patchbay side? Or will that freak out the board, i.e. having to drive the mix buss and the other device? d./
V Vetsen Well-known member Joined Jun 3, 2004 Messages 149 Location Utah Jan 30, 2005 #2 This works for me on my Allen & Heath GL3. It has TRS (unballanced) for the insert. I have had no problems. Vetsen
thedug Well-known member Joined Jun 13, 2004 Messages 235 Jan 30, 2005 #3 So did you tie ring and tip together at the board side? What about the other side, ring and sleeve together? d/
V Vetsen Well-known member Joined Jun 3, 2004 Messages 149 Location Utah Jan 30, 2005 #4 [quote author="thedug"]What about the other side, ring and sleeve together? d/[/quote] Yea, that should do it. Vetsen
