Thanks for all the useful posts. I remember a high end board that used driving both VCA control ports via an inverter and I was never sure why that added complexity was included. Must have missed that it improves noise in the app notes. Thanks for sharing that bit.
Sorry for the delay in getting a diagram up, but I am traveling and my laptop went south and had to be fixed first. Murphy is always around, especially when you use an older computer.
Here is a sketch of the idea I am trying to ask for others experience with. I'm not looking for justn20 db of compression or so - this is for much higher range, and the idea is getting the amplification from the op amp, not the VCAs, by using the VCAs as attenuators in the feedback loop.
It's OK to tell me what's wrong with the idea - I used it eons ago (around 1975-80) when, as several folks have pointed out, VCAs were not as sophisticated as they are now. I agree that is quite accurate. I was thinking about a more up to date version of that circuit.
And before you dismiss the Hawksford paper out of hand because it dates back to the 1980s, take a look at the tests Duncan did of various VCAs circa 1980 something. He tested lots of VCAs, including 202 modules, various Blackmer cell designs (dbx, sliding bias, and the Valley People variation), the Aphex 1537a and VCA1001, later Allison versions, and even the old PMI databook VCA circuit using MAT04s with 5532s instead of the originally specified op amps. Hawksford also sent Duncan has demo version and he included measurements of it as well in his findings. It performed quite well using LM394s duals in a class A design.
The Hawksford paper I was referring to also speculated (near the end) that a cascaded VCA design would be advantageous to try with Blackmer cells operating in class AB in terms of performance at high levels of attenuation. NOTE: Hawksford's design was operating in class A and still had very low noise and distortion, both when tested at 0db, and tested at 60db of attenuation.
Again thanks for all the ideas and experience shared.
