stevecrossrock
New member
- Joined
- Jan 23, 2021
- Messages
- 1
Hi all,
I recently did a Lola DIY build, and I've got a few different issues.
-I'm getting clean audio through the preamp and into my DAW, but nothing registers on the Lola meter. When I first turn it on, or hit the phase switch, or hit the phantom power switch, I see a surge on the meter. But nothing registers on the meter when actual audio is coming through.
-When I push the phase switch, I get a very loud nasty pop. Also when turning the top gain knob/switch, as it hits each position, I get nasty pops. The pops get louder as I turn the gain down, and softer as I turn the gain up, counterintuitively.
-The op-amp on top (closest to the edge of the main PCB) has way hotter output transistors than the other op-amp. These are getting hot enough to burn a finger within a second of touching them.
Do any of these issues seem connected, or seem like something that's a common problem/easy fix for an intermediate level solderer/tinkerer? Or should I just jump to sending it in for repair?
