Ian MacGregor
Hi
I'm currently helping a friend tech some issues with his Neumann cutting lathe. We are in the US, so the lathe is running off a 110 V to 220 V mains transformer. I need to look at some signal voltages inside the lathe and I'm a little unsure of the proper way to reference the scope ground probe. The scope would be plugged into the regular wall 110V socket. What is the best way to go about this? Am I fine just attaching the scope probe's ground lead to the lathe's ground?
Thanks for your help!
