Learner
Hi JH,
I donno if you are aware of the more economical Edcor transformer alternative
http://www.edcorusa.com/transformers/audio/matching.htm
I guess the down side of this transformer is that they are only 1:1 ratio which does not add any gain to the signal comparing to the original UTC? I have been looking at adding an op amp gain stage after the transformer and making the input switchable for either low impedance 600ohm input from the transformer or high impedance input direct into the op amp. Or replace the 600:10k transformer with a current to voltage amplifier.......
Likewise I would like to do that to the output stage also, adding an op amp at the output stage :shock: :? with a buffer for low impedance output , straight out of the opamp with 10k neg feedback for hi impedance output.
Personally, I don't like the idea or the thought of adding op amps into tube circuits. However, my engineering sense tells me that if the op amps are running within its linear range it should not make ANY difference.......same principle would apply to all active components.
Any thoughts?
Any thoughts?
