OK, some pics from the lovely units from Jens:
This is the main amp board:
White thing is feeback cap.
Siemens, shown here, used better wire than Telefunken.
Org and Grn coax = input primary wiring.
Front to back: xfmr assy, 2 ea. EF 804S, pwr board...
Pwr board- wires entering tunnel go to cilene dione rectum frier:
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_3.jpg
overall- pwr trans has mu can, this is ok with low level stuff.
big pwr trans no good with mu can, saturates the can.
Need heavy metal.
Heavy metal on left is mu shield for in/out/choke assy.
Selinium bridge (no ct on pwr trans) is in that black can.
Circuit board with Freds stuffed in can to retain orig look.
I would not trust those seleniums, they are pretty old and tired.
Reminds me of my days suffering thru Blaupunct car stereo repairs.
Compact, jeeves!
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_5.jpg
in/out/choke assy- Telefunken assy on top of Siemens assy.
choke missing cause needs rewind:
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_6.jpg
orig 3 chamber chucked up fo some #44:
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_7.jpg
input on rt, has newer seperators, clear plastic as opposed to older permali.
sec-pri-sec-sec-pri-sec
that brekout wire melts when you look at it.
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_8.jpg
xfmr assy brkt- probably stainless to avoid mag field coupling.
all transformer and choke wiring has to be unsoldered before you can work on any of the iron. Permaliu header plates for terms.
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_9.jpg
this is what you will find inside the selenium can.
I was going to leave filter caps for orig sound, but I noticed some swelling and fever among some of the caps so an upgrade willmean more depedability and less hum, possibly better sound.
http://vacuumbrain.com/The_Lab/Telefunken/Jens/jens_a.jpg
