This is a hi potter:
It is good to 5000 volts, ac or dc, as I just found out.
I snapped the pic at 4.5 kv, then forgot to turn it off before grabbing the lead to hook up the victim.
Don't use the hi potter if you are hi on pot. :grin:
But, current is limited to 500 microamperes, or about half a mil, in tech lingo, so I barley even felt it. The leakage light usually comes on just before the "terminal" light.
If can do no destroy testing, but I don't trust anything after the leak lite comes on.
Here is a vintage V72 pwr trans.
Luckily, it has seen better days and a couple of the coils are open, which is good for me, if yo catch my drift.
:green:
I always wantede to know if the white coats really knew their stuff, so here goes nutin. I will rewind this baby with Nomex and modern wire, so it will be good for at least another hundread years, or until Jenns croaks, which is a disytinct possibillity the way I am going, or whichever comes last. :razz:
It comes in a mu can for low static, lined with a piece of paper so the lams don't short at the ends.
http://vacuumbrain.com/The_Lab/TA/Telefunken/Jens/v72_hipot_b.jpg
Set it up:
Voltage, up, up up , up up up up, up up...
it's hard to get good British plugs, ya know.
Sombitch made it all the way to 3 KV AC!
Going from ground to any terminal.
Term to term had the same 3 kv.
Pretty good, since the insl must be aged to toast by now.
The White Coats in the XFMR Dept get an A+.
Now the fun part, checking out all the carbon tracking inside this bad boy.
Whopeee!
FYI: Every xfmr you buy should have a hipot stamp somewhere on the core or elsewhere. By law in the US at least.
