how do you figure out how much distributive capacitance there is in an inductor coil?
there are a ton of methods that you can research on the internet, most are related to RF coils and done by ham radio operators and PhD's, these are the guys you want to avoid unless you are in prison and have a lot of time on your hands,
so we reach for the bluebook, the bible, RDH4, and turn to page 225.
then we back that up with a resonant freq calculator like>
http://www.deephaven.co.uk/lc.html
so we use the data points off the "inductance" graph for rez peak freq and Henries to get another ballpark figure,
shown below is the RDH4 method, you start with the length of the winding, which in out case is about 7/8" inch for a 625 EI bobbin, then follow the red line to the mean turn length of a single winding, then you traverse horizontally over to the winding thickness, which is the build height of ll the turns (blue line), then you angle up to the right edge of the chart (green line), then you come back horizontally to the number of turns-21,000 (yellow line) then slant up to the right again to red the distributive capacitance in picofarads (black line).
so we read about 60, but remember we divide by 9 since we have aa 3 chamber bobbin, (3^2=9),
this is a crude method, and so is the graphical solution, but they both get you pretty close,
so C-d = about 7 pf.
now if you punch in various graph values into the LC calculator, you cn check yourself to make sure you are not way off the mark for C-d, punch in 7 pf and fiddle with the choke value til you hit 1800 hz, in this case we get 1100 Henries, which is different from the chart, so maybe the RDH4 value can be tweaked to give a higher Henries reading, like 4.5 pf and 1800 Henries,
why does inductance go up? core loss matches copper loss and the Q of the core is maxing out for that particular gap,
now we can adjust our graph to give better approximation of actual inductance, see next post>
