v72 input pad again
salomonander
simple question i could not find an answer to:
i have a rack with 10x v72 preamps. the input pads are a 10k log pots. is this value fine?
Probably not.
I would suggest using a switchable fixed 20db pad on the input and a variable fader like your 10k pot on the output.
Are you sure the pot is on the input and not the output?
Regards,
Mark
Biasrocks said:
Probably not.
Regards,
Mark
Are you sure 10k isn't too high for output? I used more like 1k in other preamps, works well.
V71 should be based on the same circuit as V72 and i red it has resistor switchable gain from 19-43dB. It might be done with cathode resistors, similar to Lorenz V241 at 20,25dB, can't find V71 schematic to see what it is about.
maybe have a look at JLM GoBetween plus variable gain Kit.
A search on JLM forum is also worth to do.
ROCK-ON!
hey
i just did some reading. am i right that i need to build a u-pad in order to get a proper input pad? so a 3 pole rotary switch if i want to have some options? cheers
ps: im pretty sure that the pot sits on the input. ill have to double check though and im on vacation now...
hey
regarding the pots.... could i use them as output faders? or is the impedance wrong (v72 have 32ohm the pot is 10k)?
ps: i want to go straight to my converters after the pres. my converters have a 10k input impedance. i was told to try strap a 390ohm resistor between hot and cold on the v72 output in order to match impedance. but i have no clue how connect this all to a pot on the output. would be great if i could use my 10k pots somehow. they are very nice alps and setereo.
