trancedental
A Red5 Audio RV15, I was hoping to use this as donor for a DIY clone, the PSU looks like the usual non pattern switch Alctron / Apex type, however the microphone PCB size spacing is too narrow at 30m width, 85mm length & screw spacing is 25mm. So too small for the Groupdiy mic PCB projects.
I think I could try some mods, although there are some SMD components included on the PCB, I'm assuming it's a Apex 460 / 450 circuit as the through hole components are familiar, 3 x 1uf / 450V, 2 x 220uf / 16v electro's, 2 x 100K & 33R, 47R, 3W? resistors, 1uF / 250V film cap.
The usual C9 / C10 caps on the secondary transformer outputs are SMD ceramics, with added resistors & other components.
I've tried old USA 6072a & Mallard M8137 / 12AT7 valves so far, looking to buy a better capsule, maybe a 47 type instead of the 67 type installed.
I'm not sure if I can get a PCB transformer upgrade so the original will stay.
IMG_0354.jpg104.9 KB
IMG_0356.jpg98.2 KB
IMG_0362.jpg74.2 KB
IMG_0363.jpg89.8 KB
IMG_0366.jpg102.6 KB
IMG_0367.jpg105.2 KB
IMG_0379.jpg78 KB
IMG_0385.jpg88.1 KB
IMG_0386.jpg98.2 KB
IMG_0387.jpg105.5 KB
IMG_0371.jpg81.2 KB
IMG_0382.jpg88.8 KB
IMG_0390.jpg72.6 KB
IMG_0392.jpg103.1 KB
IMG_0394.jpg82 KB
IMG_0400.jpg96.3 KB
IMG_0403.jpg65 KB
