The voltage is adjustable from 0,7V to 330V via R7, the current can be limited in the range of 30-170mA via R6.
If you need any further information I can translate for you.
This one might offer better regulation if you can live with 5 mA quiescent current: http://www.national.com/ms/LB/LB-47.pdf . In 2010 one would rather use a MOSFET a la IRF820 instead of the Darlington pair.
