My original post in English:
I’m surprised no-one ever made a liquid electrolyte variable capacitor - bit of engineering as far as a liquid sealed tank for a 3 gang but in those days there was a lot of fine engineering just to make an air gap tuning cap and things were big. They could have made them smaller using liquid
![🤓 🤓](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f913.png)
maybe larger values suited to audio
![🤔 🤔](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Your reply:
Elvileg tényleg lehetne, de több okból sem készült el. Rádiófrekvenciára teljesen alkalmatlan, mivel az ionvezetés rendkívül lassú. Már a hangtartományban is problémákat okoz. A nagyon erős hőmérséklet-függés miatt teljesen alkalmatlan ilyen célra. Csak az egyenirányítók utáni pufferkondenzátorra használható (néhány évig, utána cserélni kell)
(Could you please check your posts - they are not coming through in English) Google translation of your reply:
In principle, it really could, but it was never completed for several reasons. It is completely unsuitable for radio frequency, as ion conduction is extremely slow. It already causes problems in the audio range. Due to the very strong temperature dependence, it is completely unsuitable for this purpose. It can only be used for the buffer capacitor after the rectifiers (for a few years, after which it must be replaced)
Not referring to RF here
I was more referring to the possibility of using liquid electrolyte variable capacitors for audio as this type of electrolyte was already being used for wrapped fixed value electrolytics.
Varying the R in an RC filter is obviously a far simpler solution, but it would be fun to take an old tuning capacitor, get the plates coated with the appropriate oxides and polymer and use a liquid bath of a water based electrolyte (like used in the old water based electrolytics with a paper spacer soaked in electrolyte).
The use of carefully profiled metal plates with close spacing was convenient for RF tuning and using the right gap for high voltage applications, the ones used for domestic receivers had closer spacing and could have 3 gangs of up to 1nF each, in parallel would equate to 3nF - if this could be multiplied by 10, 20, 100 times by using liquid you’d maybe end up with useable values for audio purposes. There were also differential variable capacitors that as one stage increased in capacitance with rotation, the other would decrease. You can buy kits to build your own variable capacitor as well and with a bit of modding they could have very close spacing but there are plenty of old as well as new ones for sale.
The plate spacing air gap for a 1.25Kv tuning cap is around 0.03”/0.76mm - with closer spacing a much higher capacitance could be achieved (as there is no worry about high voltage here), C being proportional to the gap.
