why a LDR (in let's say an opto compressor) wouldn't be able to control the passing Audio just by its own varying resistance, without the use of a second fixed resistor (in a voltage divider configuration)?
Draw it, as a complete system, surrounded by amplifiers.
First assume that amplifers have low output impedance and high input impedance. This is generally true.
In the top plan, the output amplifier gets
exactly the same voltage that the input amplifier puts out. The LDR just makes the input amplifier work harder to feed the LDR. With practical chip-opamp amplifiers, when the LDR goes below about 500 ohms the amplifier will clip on loud sections, but when not clipping the gain is unchanged. The LDR would have to go below 1 ohm to affect gain, and in this case it
IS a "2 resistor voltage divider", working against the ~1 ohm output resistance of the opamp. And LDRs don't go that low.
In the second case: the output amp will get full signal until the LDR resistance rises higher than the output amplifier's input impedance. The naked opamp input impedance may be over 100 MegOhms, and LDRs are very slow to reach 100M.
I understand the concept of voltage dividers, making it possible to get a variable Voltage out of a fixed Voltage source, but in this case the voltage is already varying.
Makes no difference. We are trying to change gain, not set a voltage (though in a complete Limiter, we vary gain to keep the peak voltages to a set level).
For the most common LDRs, for controlling audio, the LDR's impedance should work between 1K and 100K. It is too hard to get them down below a few Kohms, and they are very slow to rise above 1 Mohms. In the LA2, the designer picked about a 30K threshold value. This is much higher than normal pro audio source impedances (under 600 ohms, maybe 10K with input transformer) so there is a 30K series resistor (actually a network: 68K series plus two 100K shunt). For maximum gain, the LDR is dark, rises above 100K, gain is 100K/(30K+100K)= 0.77 or higher. For very low gain, we light the LDR to 1K, gain is 1K/(30K+1K)= 0.03
the LDR shunts the signal to ground. At least they do in my comps
Always with a series resistor.
