It is basic ohm's law: at any signal level, the current in a 1K resistor is 10 times the current in a 10K resistor. In a class B output stage that current comes directly from the power supply.Winston O'Boogie said:Ian, I don't see how that is, unless we assume the feedback impedance around the 1st amp has also been scaled up 10 times. But if the 1st stage amp has been optimized for noise, it should be pretty low and will mostly swamp out that 10 X less load.
Practically speaking, taking typical values used in 990 circuits, the difference will be closer to 2 X less load if the network is scaled up.
