Various circuit boards
HoneyBadger Audio
Active member
Croatia
Hey everyone, I hope this is received well. I have been messing around with designing some circuit boards from some clone projects but I am no longer interested in pursuing the clone market so I thought this could be a good place to offer some of these parts up for anyone interested in doing some DIY builds. I will provide the BOM and schematics and support to all those who purchase. I'm looking to make back some of the investment for some other projects I have on the go. Here is the list of what I have:
LA-2A boards (1968 schematic) €20 (SOLD)
Neve 1290 Mic pre €15 (13 pieces available)
1176 Revision D (includes Cinemag CM3303 PC mount TX board) €16 (14 pieces available)
1176 Link board €5 (2 pieces available)
True Bypass Relay boards €5 (4 pieces available)
4 rail variable voltage PSU (2x positive, 1x negative, 1x 48V) €10 (SOLD)
SSL4K mic pre €10 (4 pieces available) **SOLD**
    61.3 KB
    58.4 KB
    55.8 KB
    155.1 KB
    113.8 KB
    154.6 KB
    133.1 KB
Interested in the LA2 boards as well, is it true to the original schematic?
Are the tubes standard sockets or pin sockets?
@nielsk it looks like its image #6 for the LA2A. Doesnt seem that would fit into an LA2A Style case, so i think im out on those. Looks like a good layout though.
Hey, yes I build these following the 1968 circuit path. The tubes are pin sockets, however if you wanted to strap them to the rear panel like a P2P you can.
This build does in fact fit in a shallow P2P case, i managed to squeeze it into the collective cases unit. The boards are 100x260mm.
    138.1 KB
