Hi folks,
I’m not sure where else I can post this question, so hopefully i’m at the right place.
I’m currently working on a project where I have created a simple oscillator using a hex schmitt trigger IC (CD401016) and the pitch is essentially controlled by an LDR.
basically, I eventually want to make my “field of control” a lot bigger than one tiny LDR. i am thinking of having a big panel of this probably about 5 x 7 feet with a lot of these LDRs so that you can use your entire body to move around and block some of the LDRs to alter the pitch.
It seems that i can’t really figure out away to put these LDRs in a way where i can still use one oscillator in the schematic (attached on this thread, straight out a book haha). somebody suggested to me to use arduinos, which i wouldn’t be opposed to, but i’m still unsure how that will work.
one solution i thought was many i can use solar panels put in series and just put resistors in them to make sure it doesn’t overload, and the amount of light the solar panels would determine the pitch (since it’s a VCO), but i’m not sure how well this theory will work as well.
any help or direction would be appreciated! this has been troubling me for quite some time now. if i’m not articulating things more clearly please let me know and i will elaborate more
