abbey road d enfer said:
dmp said:
I think a few other posts point this out - but some caps with an outer foil will have lower hum if installed with the outer foil attached to the side closer to ground.
If you flip the cap does the hum decrease?
There is a thread on the hoffman amp forum talking about this and testing caps for the best orientation (foil to low impedance side).
Orange drop caps are shown as having this effect and they need to be measured if I recall correctly - there is no indication from the pachage or label which lead is connected to the high impedance side.
That would be significant if it was a decoupling capacitor, but here, as it's a coupling cap, both armatures are at the same potential AC-wise, except at ultra-low frequencies.
I don't know the circuit but the issue is termination impedance on both ends of the capacitor. Of course this is only a concern at LF where the cap itself is NOT low impedance.
I have a hard time imagining any application except for balanced gain trims, where both ends of the cap see similar termination impedance.
Of course I am just speculating since I do not know the application being discussed, but back with my polystyrenes it did make a difference.
