andyfromdenver
Hi. I juuuust bought this from a friend. It is the 80s first 5 knob version with the two prong power cord. It had a repair in 2006 and that person changed a few of the electrolytics. It was working perfectly last night, but this morning it only gives a tiny tiny signal at the output whether direct out or echo out. I can hear the delay and chorus working it's just a whisper.
I thought perhaps the initial 4558 chip was bad (one is a buffered signal of the input sent to the direct out, blend, and feeds the second op amp before the compander chip), but I carefully placed a socket and tried two chips with same results.
Can you please help me trouble shoot.
I sent a 330hz sine wave 500mv p-p through the in. I pick it up at the tip but after the 100k resistor to .1 capacitor then the (-) in of the first stage it drops to 40mv. Is this a clue?
The 4558 gets -15VDC as it should and the bias to pin 5 is -7DCv. I get -7VDC on pins 1 and 7, is that normal?
I'm stumped. The over load light only flashes on when first powering, I can crank the level knob and can't light the overload LED.
Thank you for your help.
Here is a link to a redrawn clear schematic except mine is the internal power source not the walwart.
http://www.freeinfosociety.com/media/images/2051.gif
