Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 705
phasemation.com make MC transformers with a centertaps, and promote balanced MC signalling. I dare not ask what they want for their piece of kit.
I just measured the RB300 tone arm to "ground" (tonearm center post) , open. Cart case to "ground", open.
Left channel cold is tied to shield on RCA. I suspect the connection is done on the "wire board" inside the tone arm post.
The one channel with higher noise is now fixed, by repositioning the transformers. Likely source of EMI, line amp 60Hz magnetics. Noise is now down 65dB from 90dBspl peak listening level on both channels, i.e. 15dB above room background noise.
Some dude quipped that center-tapped MC transformers are "impossible" to get right, but the phaseme-guys seem to have confidence selling it.
The concept is correct. I suppose a connecting the shield to a center-tapped resistor could also work, just to get equal potential to shield on the pair.
The resistance could likely be much higher than the load resistance, thus not loading down the signal.
Twisted shielded pair with shield grounded at only one end is old school, https://www.hollandlink.eu/VandenHul-Wiring Diagrams.pdf.
