Voltage regulater or capacitance multiplier?
reubenm
      i'd like to know,
      is the following circuit a voltage regulator, or is it a capacitance multiplier? i saw it in the Neumann Handheld microphone schematic. secondly,i'd like to ask... does a voltage regulator remove AC ripple from mains? any help are greatly appreciated tx, reuben
    12.7 KB
Neumann Handheld microphone schematic-from Gyraf's site:
    22.6 KB
i think it's a voltage regulator (correct me if i'm wrong) ,but i cannot make out the reason for the capacitor in the bottom. on the other hand it may be a capacitance multiplier? any help is appreciated, thanks.
reubenm said:
      i'd like to know,
This is a C multiplier smoothing filter with a programmed in 2 diode drop... 47K across 1 Vbe draws a constant current that forces a 2x Vbe drop across 100k, + base current times 100k. The extra drop insures it will clean up ripple voltage
does f=1/(2*pie*R*C) apply to the output?... say the collector resistor 100k as R and the cap as C? seemed like it in experiments. tx
the voltage drop you mentioned, 2 Vbe + (Ib x 100k) ...if it is 1V drop in total ,and the ripple was 45V ripple,would this circuit still be adequate to clean ripple? tx
no..
Voltages on schemo are DC... so  42V DC on output, 44 V DC on input side, this is close to my estimate of 1.5V  In fact a diode drop of .66V would work out perfectly to 2V total.
AC ripple voltage on top of the 44V DC will only be a volt or so (?)  If the bottom or lowest part of the ripple voltage dips lower than the base voltage the transistor saturates and stops being a super filter.
