Matt C
I've got a couple questions for the group about voltage/passive summing. Since virtual earth summing is so much more common it's been hard to find good info that's applicable.
I've got a console that uses voltage summing to combine the 8 mono groups into the main 2-bus (in the schematic below it's labeled "matrix"). I don't really want to rebuild the whole thing with a different topology, but I'm looking at it and wondering if there's anything worth tweaking in order to optimize performance.
I was looking at the 33k summing resistors and thinking they seemed high, but then realized I don't really know what I would be gaining by lowering the value of these. The insertion loss, and the gain needed by the following amplifier (and corresponding noise) only depends on the number of channels connected, which isn't going to change. I know higher value summing resistors will reduce cross-talk between channels. But is there anything to gain from using smaller summing resistors, say 5-10k? Less Johnson noise? I should say the group outputs that are feeding this summing bus are discrete op amps with just a 10 ohm build-out resistor, no pan pot, so they have pretty low Zout and can drive reasonably heavy loads.
My other question is regarding the volume pot in the schematic, labeled "Matrix Master". Obviously it works, but I've never seen any other examples of this implementation and I'm wondering if it looks particularly offensive to anyone, or if I should just leave it alone.
