Volume Pot Question
bigswole
I use my laptop as a sound module with virtual instruments. It is a hassle to turn change the volume while playing. I was wondering if I could use say a 100k pot as an attenuator to go between the laptop and the amp?
You may use 4.7K if don't like 10K.
Anyway outputs of modern SMD rugs are usually assumed to drive something like 2K and above. Input impedances are usually around 50-100K, so 10K pot will be optimal enough.
