NoisyIndividual
Well there is clearly something I'm not seeing here and it is doing my head in.
VoxAC30CC2 which is working except for the tremelo, which causes large currents the moment the Depth control is moved off zero.
I have it on a dim bulb so nothing can blow up.
What I don't get, is that there is a tremelo AC voltage of around 200v pk-pk on the Depth pot.
This pot then puts a portion of this straight to the EL84 grids, causing mayhem.
With the EL84's removed, there is something like 60v pk-pk's worth of guitar signal on these grids, and 60v pk-pk of tremelo AC if turned up full.
This can't be right.
I changed the Mosfet MF3 just to rule it out and it is still the same.
The tremelo frequency control works as normal, everything else seems to be in place.
There is about 300v pk-pk tremelo on the Drain of the Mosfet.
I'll probably kick myself for not seeing the problem.
