VP312DI MIC NOISE
Piscolabis
Member
I am testing the VP312DI out of the rack, and I have noise only with the mic input.
The DI goes perfectly with and without post transformer.
Its posible that is was a ground noise?
Cause I dont know how to conect the grounds from psu to module.
Im using a JLM audio Powerstation.
Any idea.
This is my first preamp build.
Thanks to all
Please Help!!! :eek:
I give you more information:
In the past I have a bad solder in the gar2520 that made it very hot.I fixed it. Does its posible that it was damaged?
The DI goes perfectly with a clean sound.
I hear the sound of the relays.
If I disconect the mic the noise disapears.
I checked the impedance between 2 and 3 pins in mic input and is 28 ohms.
Its normal?
I heve tested the mic and it woks fine in other pres.
I am checkiing without chasis, with the 38 pin connector directly to the xlrs and PSU, how should this be connected?
Should I make a starpoint for grounds. I dont use ground between the transformer and the main connection
I follow the attached 51x schematic only with +-16v.
Sorry for my english and I will apreciate any help
Nacho
  • 500-51x-pinouts.pdf
    138.3 KB
If the pre works in DI mode, then I would think the 2520 is OK.
It may be that the circuit is oscillating when you connect the mic.
For testing purposes, I would wire the mic cable screen to pin 5 and then join pins 1, 5, and 13 to the PSU 0 volts.
Edit: You may be better off posting in this thread.... http://www.groupdiy.com/index.php?topic=40821.0
