> the meter slams to full scale until the output cap (100uf) discharges.
I like the other way. The meter is true floating. We don't actually need a differential amplifier. Wire two identical followers and strap the 3K9 and meter across their outputs. No output cap needed. The inputs can be biased with 100K to any simple splitter. Don't use a ton of capacitance on the splitter: noise here is rejected, and a huge cap will hold the input pins up after the main +24V has collapsed. Inputs brought in with 0.1uFd caps. And while I hate cap-matching, this is one case where better than 10% match may improve the pin-slam problem.
There will always be some meter bounce as the supply rail falls to a volt and different stages and sides of the amplifiers turn-off at different points.
