VU Meter for 1176
I'm not sure of this either, so I'll bump it...
Looking at sifam myself, but these are sure cheaper.
Joel
http://www.mouser.com/catalog/620/1335.pdf
Here is a direct link. Maybe that will make it easier for someone in the know to educate us more ignorant chaps.
I looked at the other link, and almost commented. Should work. The thing that's throwin my is "VU type"
If they'd just said "VU", I'd say, ya, you're good. =)
ju
It looks right from the specs..
Also, the price is a bit higher than the straight DC-types, indicating that there probably is an internal rectifier bridge.
Jakob E.
I've got kind of a crazy question. So if a VU meter is a true "VU standard" meter, then it would be completely interchangable with other VU standard meters with no changes needed to the circuit, correct?? So a nice Weston, or Simpson, VU would be interchangable with a Sifam, or one of the VU's mentioned above, assuming that the one mentioned above is true VU standard? I realize some may be a little more accurate than others, but they should be interchangable, correct??
Jay
