I have a pair of Daven TA1000-1 vu-meter multipliers I'd like to use. They consist of resistor networks B and C in the picture below, A is a meter zero calibration rheostat. I hooked each one up like this:
Ignoring the 600hm line conditions (hooking the meter + attenuator up across hot and cold of converter output, tone at -20dBFs, converters set to -20=0dBu), the scaling of the attenuator is not good. There is also some loss introduced meaning I can no longer calibrate the 0.775V output of my DA-converter to a 0VU reading. I am assuming this has to do with the mismatch of power vs voltage measurement standards, dBm vs dBu.
If I created an isolated 600ohm line, would that work? I'd like to try. This is what I came up with:
I am hoping this would put the meter + attenuator between a 600ohm source and load, with a voltage equal to the input voltage. Considering unbalancing the input with a transformer.
The value of the feedback resistors is just a guess, apart from being equal. Maybe they should be higher to not disturb the voltage across 600+600ohms?
Any comments appreciated!
Edit: came up with this to see if 600ohm line helps:
Connect to a dedicated output calibrated to produce 0.775V across the 600ohm. Would still prefer something closer to the first suggestion for the meters to be a bit more universal in the analog world, but this should at least tell me if the multipliers work as expected.
