trans4funks1
- Joined
- Feb 4, 2013
- Messages
- 328
I have built a bench test circuit for a PSU for tube mic DIY and have a question about the wattage ratings on the series resistors in the RC circuits.
The design is based on a 10mA current draw at 120vDC with the idea that it can support the choice of a wide variety of tubes. I am having trouble finding tube data for anode current at 120vDC. I have looked at various tubes (12ax7, 12at7, 12ay7, Ef86, Ef800) and it seems like the current draw can vary from 0.5mA thru to 8mA depending on which tube you select, so I'm designing for 10mA with the idea that the load, represented by R5 (12kOhm) will actually be a combination of a tube and some particular value of resistor wired in parallel.
I am writing to request that someone please review my thoughts about rating the series resistors, R1 through R4, for wattage and correct me if I am making a mistake.
Each of the series resistors, R1, R2, R3 and R4 drops the voltage approximately 10-15 volts.
15volts x 0.01Amps = .15 watts
R5 drops 120volts. R5 will be sized to compliment the load from the tube, so each particular choice will experience a different current through it but the worse case is
120volts x 0.01Amps = 1.2 watts
I will appreciate correction or confirmation regarding the wattage rating of the resistors.
