matta
Hi Guys,
I'm working on my LA-2a, it was built on Drip's original V1 board and has been working everyday in the studio for over 5 years without issue, then out of nowhere it started being intermittent giving hum, distorted signals and the like. I've uploaded a clip HERE
It's compressing, the meter is showing GR and I'm hearing it, in between the noise.
I've troubleshot it by checking all the voltages, all seem to look good, checked the grounds, all ohm out even replaced all the tubes, one by one, still the problem persists :-\
I'm not a wizard with my scope, but know the basics, threw it on and the input seems fine across R6 into the GR circuit, also good on the Threshold and Make-Up gain pots, but tested on the output at C5 and there is what looks like a lot of ripple and the occasional spike that goes off the chart and pegs the VU meter.
I've uploaded a short clip of me taking reading with my scope, HERE. The noise you can see is at the junction of C2 + R13, as you can see the gain knobs works as does the gain reduction. At the end I move to the gain knob, and it looks clean.
Any ideas where to look next? As shared not the tubes, pulled and replaced each one, so the noise/ripple is coming from somewhere else.
Thanks in advance
Matt
Thanks in advance
Matt
