Hi.
I'm putting together mix amps for my console, and am wondering about optimum source impedances for the circuit. It is basically identical to this one:
http://www.tenmilecreek.net/images/ssl/ssl_82E26.pdf
I just used SSM2210 instead of LM394, and added some NE5532 output A biasing.
In SSL4000 this mix amp is fed via 15k resistors. Was it 64 channels going on SSL4000 into this mix amp? If so, then for 64 channels 15k gives source impedance of 234ohm, is it? (96 channels - 156ohm, 32 chan - 468ohm). How many channels was usually connected to this mix bus in SSL consoles?
I have 24 channels, and would like to go with optimal mix resistors, so that noise is minimal. I have NE5532 buffers on channel outputs, and could go down to 1k with mix bus resistors. Would anybody have info what is OSI for this amp? Or how to calculate it? And how low can I go with mix resistors for 24 channels, to keep currents within normal?
And what about ground mix resistors on channel grounds (the ones going from channel grounds to mix buss 0V)? Should they be the same value as signal mix resistors?
What would be best values for summing resistors (signal and ground) from 24channels into this SSL_82E26 mix amp? How to calculate them?
Thnx
gnd
Thnx
gnd
