what are these connectors called?
capacitorless
Denver, Colorado
I want to source a few connectors for a PCB-based guitar amp mod project. Anyone know what these are? They are wired up to switches, to similar connectors on another circuit board, and to the power transformer and choke. If there's not enough detail in the photos I'll post more.
Check the pin pitch, there may be multiple options, likely 2.0mm and 2.54mm. Also double check the latch style, there are often connectors with nearly identical pin style which have a slightly different latch mechanism molded in the plastic housing.
[edit: I see Ian and I had the same thought at the same time]
