Opps. Forgot to attach it.Im only guessing because theres no schematic ,
equalisation ?
Interesting.LPF to filter out RF? Cut off frequency seems to be 80KHz, right?
If you take into account a source impedance of 200 ohms, the response is petty much B'worth.Whether the inductors shown are really 'inductance only' or have ant resistive damping as well could be interesting as they might give a slight boost
Would the inductance of the secondary come into play?LPF to filter out RF? Cut off frequency seems to be 80KHz, right?
Yes. As well as the reflected impedance of the capsule, which dominates.Would the inductance of the secondary come into play?
It could be. However, the way it's drawn, it appears more like two separate inductors.Possibly a common mode choke
Yes, but not as efficiently as a real CM choke. You an't except more that 20dB CMRR with separate coils. Proper CMRR relies on very strong coupling coefficient.Wouldnt two differential mode chokes placed in very close proximity cause an interaction between the two coils and provide some cancellation of common mode noise ?
They shouldn't really, as long a they are properly sized for the actual source and load impedances.Does the type of inductor , com or dif mode , have any effect on the equalisation curve ?
Noise suppressors use a CM choke (with very high coupling between sections). The filter in the mic is not clear as it's drawn.Exactly this kind of noise supression filter is used to suppress the AC line noise in front of the power transformer. One can buy it in capsules including the AC connector and a fuse. I use it, too.
