what does this jumper do on the Green Pre?
Mbira
Austin, TX
Does this ground to the chassis here?
:guinness:
Joel
Peter of SA is of course da man to tell us about it, but being a Peter as well here's my take on it:
I bet he intended it as a convenient 'GND'-attachment-thing for during testing.
Then you can have never enough GND-arttachment-possibilities: earth-clips of scope probes, temp. power-supply-connections etc., etc.
So as in his pics I made that jumper a big loop. it's in fact not a jumper, the PCB-trace underneath continues.
Have a good weekend,
Peter
So should it be attached now in the final version, or would that create ground loop problems? These are going to be stacked vertically in a 2u chassis, so running a line to ground from there would add a bit of inconvenience if it's not needed.
Joel
