Hi there,
I know what you think, an other topic on Neve V serie mods but i need to understand something and you can help me.
I 'm thinking of replace ICs in my Neve VR36 to reduce temperature, power consumption and remove electrolytic capacitor between stages.
My question is why if i use modern op amp like OPA1662 or OP1692 to replace the old NE5532 i can remove the 100uF caps between each stage of the circuit ?
Does it mean that i can remove all those caps if i replace the TL074 with OPA1664 (or equivalent). What op amp can be used ? Modern one, like OPA16XX series ?
Then i also read that in the EQ section i can not replace all ICs, particularly IC10 with modern op amp cause it will "sing like a bird". and that some replace the 10uH ferrite chock with ferrite beads, why ?
If some body can take some time to explain me that thing i would be grateful
Thank you
Thank you
